Gjac wrote:
There are two main reasons why I wanted to down size. The first is two front end failures while taking a corner. The first was at 25 mpg getting on an interstate in Ohio. LH ball joint just collapsed. I took about a 2 weeks to get it fixed. It was still a harrowing experience for my wife. After it was fixed I assured her it was as good as new. The shop I used back home told me that the shop in Ohio put the wrong ball joints in so they replaced both sides. The following year in Montana while rounding a curve at 60 mpg the rh ball joint failed, dropped, blew the front tire and we almost flipped over. I had all I could do to hold on to the steering wheel and bring it to a stop. To make matters worse the sparks or hot rubber from the front end or hot tire pieces started a fire in the dry grass and came within 20 ft of the MH before some passer by's helped get it under control before the fire dept came. This was in a remote area of Mt. and we could not find a truck stop to work on a Class A MH. Not many truck stops want to work on Class A MHs anyways. The MH had to be towed 250 miles west to Great Falls Mt because that is the only place the insurance co. could find that would take it. The accident happed in July, we did not get the MH fixed until Nov.so we had to drive back in the snow. That really did it for my wife. Turns out the shop back home put in undersized ball joints twice. All P-30 chassis are not the same( another story). So when my wife thinks about all the mountainous windy roads we traveled out west and a front end failure occurred we would defiantly gone over the edge. So the two main reasons is two accidents one almost fatal the second when you need chassis work on a larger MH in a remote area in the summer time when many folks travel finding a truck stop to work on one can be very difficult. I would much prefer a 30-32 ft Class A with a straight front axle but my wife says 3 strikes and your out.
For onroad handling, stability, and ease of maintenance and repair I recommend a Class C as small as you can tolerate ... and look for it built on a Ford E450 chassis - NOT an E350 chassis. The additional ruggedness and general overall "chassis overkill" of an E450 for a small Class C - that will never be an overloaded chassis regardless of how much stuff you want to pack it with, including full tanks - makes for a great combination that you can trust to take better care of you.
Many folks could not tolerate this, but -> stay away from slides. They just add a level of complexity and structure compromise that is not needed for ultimate coach integrity and reliability mile after mile, season after season. For the maximum coach interior feeling in a slideless short Class C, make sure it's of the "widebody" design style - from 100 inches to 102 inches wide.
Our first new motorhome has been - right from the start - a great fully self-contained little rig that has taken us on trips up to 10 weeks long all over the U.S. and out into the middle of nowhere in the Western U.S. deserts for us to explore and camp (we're rockhounds). We can park it just about anywhere in parking lots and in public campgrounds with tent-size spots if required. It is rock solid stable on the open road on curves and in high cross-winds, but I did have installed Koni FSD (Frequency Selective Damping) shocks in the rear to soften the jolts from highway cracks - due to it's under-loaded E450 chassis.
Our Itasca (Winnebago built) E450 based, widebody, slideless, Class C has all of this in it's 24 foot length:
- Two queen beds (rear corner and cab overhead).
- One full size bed (dinette quickly converted if/when needed).
- Built-in privacy curtains for the rear bed and bathroom, cab overhead bed, and cab area.
- A built-in 4000 watt generator that is quiet enough to be tolerated inside and outside for hours.
- A 13,500 BTU air conditioner, fully ducted throughout the coach.
- A 101 inch wide coach design.
- Non-stock larger diameter tires for more off-highway clearance.
- One swivel/sliding lounge chair.
- Swept up rear coach wall design for a better departure angle on off-road ruts and uphill driveways.
- An 18 gallon propane tank (60-65 lbs. of propane when filled to ~80%).
- A 25,000 BTU furnace, fully ducted throughout the coach.
- 45 gallons of fresh water.
- 39 gallons of black water.
- 29 gallons of grey water (the black and grey tanks can be combined).
- Two 12V Group 31, 115 AH each, deep cycle AGM coach batteries with monitors in the coach and the cab.
- No low hanging coach outside components (all plumbing/electrical items are high up in locked outside cabinets).
- 7 outside steel lined cabinets, with two of them extending cross-wise under the coach floor for long items.
- A good performing propane/electric refrigerator for drycamping with no sun, if necessary.
- A dry bath with a good sized shower, including a double-pane skylight over the shower.
- A solid heavy duty exterior ladder for roof access anywhere, anytime.
- An automatic outside coach step that does not portrude lower than the coach wall when retracted.
- A 158 inch wheel base that even makes possible U-turns on most residential streets.
Here's us camped off a 4x4 road way out there in Death Valley:
