Passin Thru wrote:
Bosch fuel pumps are notoriusly unreliable. Chevy used them in their V8 Diesel which was a gas engine block, (Duramax is made by Isuzu) and they might last 50 K mi.
The Chev/GM 6.2L v8 series had a Stanadyne DB2 pump, similar to the old Roosa Master. They were good pumps, I got 110k, 120k out of the two I changed out. Considering they were less than $500 for a rebuild, I thought them a deal. Completely mechanical pump.
VP44 pumps had mechanical failures of rotor design tolerance imperfections, diaphragm faliures, lift pump caused low pressure, and some electrical issues, heat being an issue causing failure of the electronics. Sort of similar to a DB4 Stanadyne used in GM's. Different beast.
