Slojoe72's avatar
Slojoe72
2nd ac unit not coming on
Well new to me motorhome. Just trying to figure stuff out 1 thing at a time. Previous owner not much help. It's a 99 holiday rambler imperial 40' cummins 350.
Only front ac unit comes on when generator is running. Thing I noticed
Motorhome only seems to have one ac thermostat. It's by the dinning room and it's a duo temp electronic thermo. Now there is a 2 wire plug in the bedroom on the one nightstand but nothing connected to it (could that be a place where a thermostat was/goes.
Other thing I noticed was on the electrical panel. The heart interface only says the incoming ac breaker amps says 30.
Sooooooo
Thanks for helping in advance.
  • the shore power is a 50amp, but I dont not have a plug at the house to plug that in so thats why I was using generator.
    I did flip the breakers on the Gen and still nothing. I only have the one thermostat. Im thinking the there is supposed to be a thermostat on the night stand right by the bed. There is a switch for engine compartment heater, light switches, and a hole with a 2 wire plug hanging out. And once apon a time there was something screwed there because there is 2 small screw holes in the wall .
  • what is the shore power plug ?
    4 blade 50amp service or 3 blade 30amp service
    your a/c is probably NOT on your heart inverter
    did you check both circuit breakers on the Generator ?
    flip them both OFF and then back on to reset them
  • Our front AC runs off the thermostat in the dining room. The smaller AC in the bedroom runs off a thermostat that is on the wall between the side wall of the slide and the rear of the coach. Ours is a 2000 Monaco. Both thermostats are duo therm and either one will turn the furnace on. Both have heat/ac settings, but the ac is for the individual unit.
