rmoparman
Jul 28, 2017Explorer
2nd AC
If unit does not come with 2nd ac in bedroom, does it need to be framed from factory and prewired. Or can unit be put there with little effort.?
Happytraveler wrote:
My sister has a 35 ft. 5th wheel and she's having this one installed Atwood 15026 Air Command 15,000 BTU Air Conditioner Non-Ducted with Heat Pump in her kitchen area where the fan is located. The ducted air conditioner is not keeping up when the temperature when its over 100 degrees outside. She blames it on the high ceilings.
We have the same air conditioner in our motorhome. We run the basement air and the Atwood at the same time. This air conditioner can be plugged into a 30 amp circuit.
Triker33 wrote:
since you are having one ordered. Order it with the second AC to start with. It can always be used. Get at least a 13.5 one.
