Metaphor_7182's avatar
May 21, 2014
30 amp =
The RT electrical is 30 amps. So plugging it in to the 110V at the house it is pulling how many watts with nothing pulled from the house electrical to the vehicle (microwave, clock, radio, etc.)? :)
Got the answer, but needing a back check on my math.
  • This was, for the record, the most uninterpretable question I have ever read. I have no idea what is being asked here. I probably know the answer, being well versed in electronics and electricity but....
    Brian
  • Metaphor 7182 wrote:
    .. with nothing pulled from the house electrical to the vehicle (microwave, clock, radio, etc.)?
    If nothing is "pulled" it is near zero. Is that what you mean?
  • The maximum is 120x20=2,400W for 20A plug.
    120x30=3,600W for a 30A plug.
    2x120x50=12,000W for a 50A plug.
  • The microwave is only going to be pulling amperage when it is cooking something. Otherwise the clock on it is going to pull a fraction of a fraction of an amp. If everything but the microwave clock and the light on the radio are off, I would guess you are pulling way less than 1/10 of an amp. But you are probably forgetting many other loads that come on when you plug in. Things like the battery charger, the converter, maybe the fridge etc. What exactly are you trying to figure out?
  • Power in WATTS is Voltage times Amperes.
    If you simply plug in, and do not turn on any loads, you
    are using 115 Volts times 0 Amperes = 0 Watts
    If you add load, say 10 Amperes, you are drawing
    115 Volts times 10 Amperes = 1150 Watts = 1.15 Kilowatts
    This holds for a 30 Amperes rated circuit, but not for other
    types of circuits.
  • wouldn't the microwave be about 1100 watts. the clock/radio/etc. minimal?
    bumpy
