AikenRacer wrote:
I am using two 30 amp breakers that are hooked together as one presently in the breaker box that used to go to a stove that we no longer have. I bought a 30 amp RV box at Lowes. So my present wiring is the top 30 amp breaker in the box has one wire going to one side of the new 30 amp receptacle. The bottom 30 amp breaker is wired going to the other side of the new 30 amp receptacle. That is why I figured it is 220 volts. Is this wired right for a mh?
Picture or better diagram would be very helpful here , but from the description you wired 240V to RV 30amp outlet design for 120V.
If I read it right, the sparks will fly.
