santacrocemt's avatar
santacrocemt
Install additional 110 volt outlet in RV
Our Passport travel trailer doesn't have enough outlets. We often need to work at the dinette with a computer and there's no outlet anywhere near the table. However, there's a terrific spot for one right on the wall near the converter and power distribution panel.
I want to add an "old work" double gang box and put a 110V outlet in one bay and a triple USB connector in the other bay. This will allow us to use laptops and charge our phones. I have a "blank" in the power distribution panel and can get a new breaker for the new circuit.
BUT, I cannot find a single or double "old work" electrical box to mount in the wall. The most common old work boxes assume that the little fins will catch on the sheetrock of your average home. They do not appear to extend far enough to accommodate the thickness of an RV wall. I would like to avoid a surface mounted box as that could be problematic given that it would be mounted to the RV wall (which don't have nice wooden studs for mounting)
Does anyone have any suggestions...
