santacrocemtExplorerJul 13, 2014Install additional 110 volt outlet in RVOur Passport travel trailer doesn't have enough outlets. We often need to work at the dinette with a computer and there's no outlet anywhere near the table. However, there's a terrific spot for one ri...Show More
TequilaExplorerJul 13, 2014if you can get behind there you can also use liquid nails or gorilla glue to glue a hunk of wood next to the cutout that you can screw into.I used this for a charging stationUSB
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringElectrical outlet issuesInverter installOutlet problem
