This is a pictorial of the PEDESTAL WIRING at the campgorunds for the 50AMP and 30AMP SERVICE...
This is a TEST PICTORIAL for the 50AMPS and 30AMPS PEDESTAL CONNECTIONS using an AC MULTIMETER. If you cannot dupicate these reading then DO NOT CONNECT your trailer to these circuits...
50AMPS SERVICE at the PEDESTAL
30AMPS SERVICE at the PEDESTAL
This is what using the 30A to 50AMP ADAPTER looks like
This is a close up of the 30A to 50A ADAPTER showing how the HOT 1 ans HOT2 legs are wired together. Using this adapter feeds both zones of your 50AMP trailer but you will be restricted to only 30AMPs of service.... You will have to watch what you have turned on at the same time otherwise it will trip your breaker.
The beauty of having the contractors to do this is they are bonded and when they blow up your appliances for wiring it they way they think it is suppose to be they will replace your burned up items. You doing all of the wirng it will be ALL ON YOU...
submitted for info only - Pictorials from GOOGLE SEARCH
Roy Ken
