- 1BryNelsonExplorerYes you can. The 50amp to 30amp RV adapter for a 30 amp coach does not plug into the 4th leg of a 50amp RV plug.
- gsf35099ExplorerInfo from another site asking the same question:
If you are talking about plugging your 30 Amp RV into a 50 Amp plug at an RV campground, then yes you can safely do it. All you need is a 30 Amp To 50 Amp Adaptor which has a 120 volt 50 Amp male end and a 120 volt 30 Amp female end. You just plug your 30 Amp RV cord into the female end of the adaptor and plug the male end into the campground's 50 amp service plug.
If you are talking about plugging your 30 amp RV into a 220 volt 50 amp Welder plug then no that will not work.
Here is the web address:
http://www.everything-about-rving.com/can-i-plug-my-30-amp-rv-into-a-50-amp-plug-without-damage.html
38,761 PostsLatest Activity: Nov 22, 2025
