wa8yxm
Apr 20, 2017Explorer III
You might modify the area around the outlet.
alternative get a pair of adapters, 30-50 and 50-30.. Some of those have FLAT wires (3 wires side by side) and don't much mind a sharp bend. The other one (the one with the 50 amp plug) will likely have round wire.
But a mod of the area around the outlet sounds best to me.
Let me GOOGLE. (Well Yahoo Search) I only found Right Angle plugs but some have shoreter bodies and may fit better.... And as I said, you can go with a flat cable,,, YOu coudl even use a 30-50 (30 amp male) and sli e the 50 off and att a TT-30 Outlet to it. That too would work.
