- dedmistonModerator
dcmac214 wrote:
Don't have, never had, a wastewater tote.
But NRALIFR was so cocksure about it. :BNRALIFR wrote:
Good grief. It’s to connect a blue waste water tote to your sewer drain cap. - JoeHExplorer IIIDo you have a water softener ? Need one to backflush them
- dcmac214ExplorerOP here. Thanks all. I guess it'll remain one of the unsolved mysteries of my life.
Didn't get it for a hose reel, don't have, need, or want one.
Blackwater tank flusher hookup is female.
Same for the freshwater connection.
The water filter we use has male-female connections, ensuring correct flow direction.
Washer hookup that short and female-female? Never saw one. Home washer hoses both male-female.
I guess I'll throw it out. Sure thing that within an hour after they empty the dumpster I'll have a critical need for it! - NRALIFRExplorerGood grief. It’s to connect a blue waste water tote to your sewer drain cap. Of course, you have to have a drain cap with an integral hose connector.
:):) - opnspacesNavigator IIII second the suggestion that it's for a threaded sewer cap to a blue tote.
- Guy_RoanExplorerBuy another with a male connection at each end. Connect each end of the male to each end of the female. Now get a stake a pound it into the ground and you have a nice ring toss game.
Guy - dodge_guyExplorer IIwashing machines use that style. my cheap pressure washer requires it. and my tote has a male connector as well as the sewer cap on the MH.
- bob213ExplorerBypass hose replacement?
- wanderingaimlesExplorerDo you use the HelMart blue water filters? Those have male threads on both ends forcing you to use a double female to connect it to the hose bibb.
- wa8yxmExplorer IIIStandard washer hose (For a washing machine) Home units are usually 3 feet long but for an RV.. may have also used it with a filter (home made) or ( use one on a waste line as well.
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
