Yeti_plus
Apr 20, 2017Explorer
If the receptacle is in a standard 4 inch square box you could remove power to the coach, loosen off the mounting screws on the box and rotate 90 degrees so the plug is pointing in a different direction.
I don't have this setup so I am only guessing.
Brian
Brian
