lanerd
May 09, 2015Explorer II
Most (if not all) DPs of your length and engine size has a 10,000 lb towing capacity. However, each coach will be different as the towing capacity will be determined by the current (ready for the road) gross weight of the mh subtracted from the mh's gross combined weight limit.
So, in order to know your actual towing capacity, you must weigh your mh first.
However, that said, I'm sure pulling the Tahoe will be well within the coach's limitations.
Ron
Ron
38,777 PostsLatest Activity: May 24, 2026
