wolfe10
May 09, 2015Explorer
Look at your GCWR (Gross Combined Weight Rating). That will tell you the most your combined coach (when loaded) and toad can weight.
ALSO, your chassis will have a towing rating.
ALSO, as MountainAir05 said, you will have a hitch rating.
You should not exceed ANY of the above.
BTW the HP rating alone doesn't tell the whole story. Could be a Cummins B or Cummins C. BIG difference in torque between the two. Depending on year, the B could be either a 5.9 or 6.7 liter. The C is 8.3 liters.
38,777 PostsLatest Activity: May 24, 2026
