Ivylog
May 09, 2015Explorer III
Welcome to the forums. It would help if you added which Cummins engine but it's probably the 6.7L ISB engine. Great little engine but at only 800 ft/lbs of torque in that heavy a coach you will notice adding 1500+ more lbs. On some of the high/long passes in CO I'd probably let someone drive a Tahoe up and over. This will make it easier on the ISB and your brakes as they can gear the Tahoe down too on the way down.
38,777 PostsLatest Activity: May 24, 2026
