3M film on front of rig is starting to look like **** with what looks like mold underneath it.I had a quote from Diamond shield to remove and replace for a crazy amount of cash.. since then I've seen ...
So just to clarify, the rhino covering that is being discussed here is not the black rhino skin that you see in the bed of trucks, this rhino finishing/coating has the same paint job/artistic pattern-designs as the original design (they just use/create a stencil from your design) of the rig. Once the paint job over that rhino skin is done, you don't even notice it unless you're 2-3 feet away from it.
