drifterpilot's avatar
drifterpilot
4-way Flashers not working
4-Way Flashers not working
Turn signals work. Brake lights work. Running lights work.
When I step on the brakes, both turn signals on the dash illuminate and stay illuminated as long as I stay on the brakes.
I replaced the turn signal flasher.
What should I check next?
Thanks
  • Have you replaced any bulbs outside the coach in a while? If so I would pull those bulbs and see if the problem goes away.
    If the bulbs are good I would look at the flashers. There are usually two flasher units in a vehicles. You have already replaced the turn signal flasher. You need to find and replace the Hazard light flasher.
