Ivylog
Jan 10, 2019Explorer III
Often it’s the nut behind the steering wheel that needs tightening. My “new” ride had a steering stabilizer on it and I found it made driving tiring where my previous rig (same chassis) did not. It wanted to center the steering even though with a cross wind the steering needed to be off center. It also made turning the steering wheel harder so I disconnected it which got it back to what I was used to. I recently needed the steering wheel turned 45 degrees to go straight...was glad I didn’t have to fight the stabilizer too. I may make a air operated slip connection so the centering can be moved from center and reconnect it.
I would not add a stabilizer unless it is adjustable.
