BFL13
Nov 14, 2018Explorer II
pnichols wrote:BFL13 wrote:
I am not up on today's fashions in propane tank size per foot of Class C, but note that 40lb in a 27 footer seems small.
Our 1991 came in three sizes: 24, 26, and 28. The first two had 45 lb tanks and our 28 has a 76 lb tank.
So our 28 is only a foot longer than that new 27, but has a 76 lb tank instead of a 40. Doesn't seem right somehow. What does that 27 have instead of a bigger propane tank?
When you day your 28 has a 76 lb. tank ... does that mean it's about an 18 gallon tank?
If so, that means that the actual lbs. of propane that your tank can hold - after filling to the common legal 80% - is around 60 lbs. of propane.
I was trying to understand how that all works about a year ago, and DrewE explained (after I said the tank is marked 23.2 Gal)
23.2 gallons would be the water capacity. LPG capacity is about 80% of that, allowing for headspace. Thus, when properly filled, it would hold just about exactly 70 liters of LPG, or around 75 pounds, or the equivalent of two and a half 30 lb bottles.
38,782 PostsLatest Activity: Aug 31, 2026
