Mike63376's avatar
Mike63376
500 gallon propane tank
We are living in our jayco 232 rv till our house is raised due to being flooded out last year. I have a full 500 gallon propane tank that’s 40 feet from out rv. It has the primary regulator at the tank and I have the secondary house side regulator removed. Can I attach a gas line and run it from the tank regulator to the camper and hook up the secondary regulator to the rv?
  • The regulator you have will work fine. All propane appliances use 11" pressure.
  • I own the tank. The house regulator doesn’t seem to have any pressure ratings that I can see. Gonna order the 0.54/11 inches water columes.
  • Dusty R wrote:
    Who owns the tank? If you own the tank, then yes. If the propane company owns it then it's their responsibility and will not be vary happy if you do it.
    Dusty
    Good point plus any safety considerations.
    SIL was given a complete homme generator plus 2 large tanks. The 2 tanks were placed next to the house tank. We dug a ditch to the gen and the propane company installed the hookup at no cost. He can use any tank. That's a permanent setup unlike a RV.
  • Who owns the tank? If you own the tank, then yes. If the propane company owns it then it's their responsibility and will not be vary happy if you do it.
    Dusty
  • I installed a high pressure tap on the motorhome for the BBQ because it's more versital and less prone to low pressure regulation for the BBQs.
    The tap is shown below, note the top vertical connector which would allow a external high pressure tank to be connected if desired. You could also do something similar.
    Click For Full-Size Image.
  • YES.....
    Provided Secondary Regulator is set for 11"WC (0.4psi)
    (Should be info on reg)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
