- WILDEBILL308Explorer IIMy specks show a 25 gal tank. I just filled it from empty with 18.8 gal of propane to get ready for a trip after Thanksgiving. Happy Thanksgiving to all.
Propane is running $3.00 a gallon right now.
Bill - Horizon170ExplorerI have a 20-23 gallon frame tank plus I carry a 30# along also. I installed the extra hose kit to connect it to. If I'm parked for a while I leave the frame tank off and hook up the 30#.
Marvin - larryherringtonExplorerthanks to all for the posts. I will be more careful with my post topics. I did say 40 gal. that is a lot.
thanks to all - 77rollalongExplorerI normally go to a place in town that does home propane fills, and they also do 20lb bar-bq tanks and Propane cars and trucks. I normally fill our tank every 4 weekends of use, but I also carry a 20 lb Bar-bq tank that can and has been used when I dont want to have to move the motorhome in the winter, but wanted to work in the camper.
- BFL13Explorer IINo idea how it is down there, but up here on the Island it is getting hard to find a place that will fill tanks. Lots of places to fill or swap cylindars, but few places that have tank filler pumps (and anybody that knows how). There are "commercial" places for trucks, but I don't think? they do RVs.
So I fill it when I am near one of those few places that do RVs, whether it needs it or not. I am worried that one day, I will have to get one of those extend a stay adapters and go with cylindars. - pnicholsExplorer IIBF,
23.2 gallons is a great size propane tank for a Class C rig ... I wish mine was that large.
Mine is marked as 17.6 gallons W.C. (water capacity), which means it holds the equivalent of about two 30 lb. bottles when full. The outside area where mine is tucked away could easily hold a tank the size of yours. I just had it replaced before an upcoming trip, but we didn't have the time to get some shop to custom-install a larger size.
It's not that we "need" the extra propane capacity, but the longer time between fill-ups ... the better IMHO. - BFL13Explorer II
pnichols wrote:
BFL13 wrote:
I am not up on today's fashions in propane tank size per foot of Class C, but note that 40lb in a 27 footer seems small.
Our 1991 came in three sizes: 24, 26, and 28. The first two had 45 lb tanks and our 28 has a 76 lb tank.
So our 28 is only a foot longer than that new 27, but has a 76 lb tank instead of a 40. Doesn't seem right somehow. What does that 27 have instead of a bigger propane tank?
When you day your 28 has a 76 lb. tank ... does that mean it's about an 18 gallon tank?
If so, that means that the actual lbs. of propane that your tank can hold - after filling to the common legal 80% - is around 60 lbs. of propane.
I was trying to understand how that all works about a year ago, and DrewE explained (after I said the tank is marked 23.2 Gal)
23.2 gallons would be the water capacity. LPG capacity is about 80% of that, allowing for headspace. Thus, when properly filled, it would hold just about exactly 70 liters of LPG, or around 75 pounds, or the equivalent of two and a half 30 lb bottles. - pnicholsExplorer II
If so, that means that the actual lbs. of propane that your tank can hold - after filling to the common legal 80% - is around 60 lbs. of propane. - 40 gallons or 40 pounds? Either way it could just be the gauge is a bit conservative. Have the tank filled and see what was really used.
If it is just 40 pounds that is not much propane and might be right. My 26' trailer carries 2x 30 pound cylinders.
Also a good time for a leak check as this will also use a bit of propane. (from experience) - BFL13Explorer III am not up on today's fashions in propane tank size per foot of Class C, but note that 40lb in a 27 footer seems small.
38,780 PostsLatest Activity: Aug 05, 2026
