the bear II wrote:
On my 454 the several times I had a heating issue it was:
> I also discovered the factory temp guage read almost 20 degrees high. So when it showed 210 I was closer to 180.
> Found a Royal Purple product that works well to help keep the temps down when going up hill or in stop and go traffic. It's called Wetter Water. Really works great. Available where auto supplies are sold.
Thanks. I may be panicking for no reason. It hasn't actually boiled over yet. The stock gauge may not be all that accurate. I just have "C" and "H" with a redline toward the "H". Under most conditions the needle hovers near the center of the gauge.
I used water wetter in my GN to keep it cool. It was bored .060 over and ran hot. Water wetter helped a lot. I'll try it!
