BFL13
Sep 07, 2018Explorer II
ronfisherman wrote:
Hoses may go to coach water heater
Yes , it does have a heater somewhere (that uses engine heat) for the RV part with two small air registers in the back. There is an under dash switch to turn their fan on with ?three? speeds. (left side of steering) I have that switched to off. This is independent of the RV furnace heating system.
I have the two hoses that look the same side by side, but hot coolant only coming out of one of them although both have holes in the same place where they were on something hot (exhaust pipe?) the other hose is empty with the engine running.
The water heater for the Rv is an Atwood propane-only type. AFAIK it is not involved with the engine cooling system
