BFL13
Sep 08, 2018Explorer II
I will be back to the RV on Monday to finish the repair and drive it home. At least now I know (I hope!) what needs doing. Fix both hoses. I will leave the doghouse off for the trip home so I can see if my fixes are holding.
If I have time, I could maybe try it with the one hose fixed that was leaking and see if water now does come out the other.
ISTR one of the pamphlets was about a rear heater or it might have been in the "incomplete truck" manual so there might be some plumbing info there.
Some time ago I did try that under dash switch for the rear heat, engine running, and did get hot air from the two little registers back in the RV part. That just helps keep the RV part warm while you are driving. Normally the furnace would be off then.
I will post a follow-up.
