BFL13
Sep 10, 2018Explorer II
The photo shows on mine ok.
I can't find a link, but it is called, "AtwoodAIR Auxiliary Rear Heat/Cool System Floor Mount. The installation pamphlet is dated Sep 86. It is supposed to branch off from the vehicle's heater. Should be a water valve on the inlet hose, which can be "cable operated" or the "optional electric control water valve". I have not poked around the RV to find all this yet.
The manual's diagrams show it mounted under a rear couch in a big van or Class C. It has a drain hose through the floor. I might be able to find that crawling under the RV. I do have two hot air registers for it that work. The drawing shows it could have four.
The air conditioner that was on the roof was removed long before we got this ( a Fantstic Fan there now), so I suppose the "Cool" part of this Heat/Cool is gone too.
