I got the fuel pimp and strainers replaced. It's still the same. I don't see any vacuum lines off or bad anywhere. I'll get a code reader and see if there are any codes. I probably should have started there because the fuel pump wasn't the easiest thing to replace. Lol! I'm sure it didn't hurt anything though. The old fuel pump had a date of 5/4/2000 on it. Once it starts and you shut it off before it decides to die on it's own it still won't start right back up. It will start again if you wait about 5 to 10 minutes.
