PaulJ2
Nov 26, 2013Explorer
RLS7201 wrote:
Steve, Check the Idle Air Control (IAC). It's responsible for setting the correct idle speed. It's mounted on the front of the upper intake manifold, under the two hoses attached to the throttle body.
When idling in neutral, remove the wire connector and see if the idle speed changes. If it don't change, you have an IAC problem.
Richard
My thoughts axactly! Probably varnished and sticking from old fuel.
38,769 PostsLatest Activity: Mar 31, 2026
