jaycocreek
Aug 07, 2016Explorer II
It is NOT a four wheelin machine tho...it flexes and bends because it is a Class C RV. You'll bust it or flop it over if you try the Jeep thing.
This is so true..The higher the coach is the more likely to hit limbs or rocks...Living in Idaho, I can see the advantages of 4x4 on normal roads and ground clearance is a catch 22 with an RV making them more tipsy and leaning/swaying more on corners.
Looking at an older rig one must take into consideration parts for the engine and drive line...When I bought mine ground clearance was a major factor because so many hug the ground and that would not work for me and the 460 engine has parts available everywhere so far, if needed.
The twisting and bumping of off roading will work your seams looser than normal highway driving making leaks happen more often if your not aware of it(Something else I learned the hardway)..
Awesome looking RV though and it would depend on how your going to use it and what it's worth to you.Last one similar I looked at was $25k..
38,769 PostsLatest Activity: Dec 31, 2014
