Francesca_Knowl
Jun 07, 2014Explorer
dakdave wrote:^^^^That^^^^
weight should be stamped on tank on valve protector
A number will be preceded by "TW", which means "tare weight".
Which means EMPTY weight!
The typical 5-gallon size weighs a bit under 17 pounds empty, but there can be a difference in weight between two tanks since some older ones are made from heavier materials.
Also:
On Canadian tanks, weight is given in kg's and is preceded only by the letter "W" for weight.
38,782 PostsLatest Activity: Aug 31, 2026
