wa8yxm
Jun 07, 2014Explorer III
Take tank to a Propane Wholesaler who can re-cert it, They can figure it out.
ONE possible issue is contamination.. There are things that can get pumped into the tank that are NOT propane....
Also.. You said you opened the valve and nothing came out.. This is how it should be, there is a 2nd valve, inside the outlet, if there is nothing connected to the tank this valve WILL be closed. Just like a throwaway, the valve is opened when you connect to it.. Also the nut must be tight, if it's loose, the valve closes.
38,782 PostsLatest Activity: Aug 31, 2026
