bcbob wrote:
Deandec said :
“If you replace the problem GFI outlet with a standard 15a outlet, do you still have the same symptoms?” The answer is no. Everything works fine when I replaced the problem GFCI with a standard 15 AMP outlet. I checked all the visible and easy to get to connections last week but have not pulled every outlet from the wall.
B
I have had a similar problem in my garage GFI. It is caused by too much draw on the circuit when both my upright freezer and refrigerator start cooling simultaneously. I avoided the problem by installing a non GFI outlet. This of course does not meet code.
See my next post for my actual fix.
