hanko
Oct 02, 2016Explorer
usersmanual wrote:parkmanaa wrote:
Is it not possible to run a second 120v line (different phase), from your service panel to that 30 amp receptacle on your pole barn, then install a regular 50-amp receptacle?
I predict you will not be happy in the long run "managing" 30 amps for a 50-amp MH. Also I predict you will get tired of changing that 30 amp breaker due to it becoming weak from frequent tripping.
On contrare 30 amps is plenty much unless your living in it in summer while trying to run two roof AC units and other stuff to boot
so no you don't need 50 unless(like I said)
if your circuit is run in conduit, than yes you can pull in an additional wire. you could change the plug to a 50 amp plug, but if its #10 wire which Im sure it is you could only fuse it at 30 amps with a two pole breaker
38,707 PostsLatest Activity: Feb 18, 2025
