dougrainer
Jul 16, 2017Nomad
ScottG wrote:
As another recently pointed out to me, a 30A outlet is only intended to deliver 24A max continuous.
I think if you go out and check the plug, it may be quite warm. You should also check the voltage inside your RV. It could be very low.
OK, Please state where you get this information. It is WRONG. A 30 amp RV shore Power plug is rated at 30 amps and 30 amps continuous. Doug
38,777 PostsLatest Activity: May 24, 2026
