wa8yxm
Jul 18, 2017Explorer III
To address a couple things
The "30 amps is only rated for 24, (I thought it wazs 27) amps continous applies to the circuit breaker.. But though the plug is rated for 30 full time.. Darn few can survive that.
Second: To answer the O/P's question
The only danger in running both A/Cs at the same time is the click of darkness.
That is. Tripping the circuit breaker.. If it does not trip.. you are good to go
DO, however, monitor voltage and check the plug for signs of melting.
38,777 PostsLatest Activity: May 24, 2026
