Busskipper
Apr 11, 2016Explorer
Dutch_12078 wrote:
If it's not the inverter, trying turning the circuit breaker on the post off and back on. You may only be getting power on one of the two hot legs. Both sides are supposed to trip if one does, but I have seen instances of that not happening. Another possibility is a problem with the transfer switch with one leg not making contact on the shorepower side when the generator is off, but connecting to the generator when it's running.
Sounds like the issue - see if you can change site or plug in through your 30 amp convertor - that might work - if not on 30 then most likely the inverter is the issue.
Let us know how you solved the problem.
BOL,
