FIRE_UP
Aug 18, 2013Explorer
Ct,
While I wouldn't be too concerned, a call to Allison or, to a service center for Cummins/Allison of your choice might settle your mind. Ours does quite often, a harsh 5-4 shift, if, conditions are just right. If we're cruising in 5th in a grade and slowly loosing speed, enough to cause the trans to jump to 4th, it can sometimes "jerk" the beast around a bit. Remember, the available torque at a given RPM, can and will be felt during some shifts.
On the up shifting, most of the time from 1-2-3-4-5 and finally 6th, it's usually pretty darn smooth but, it's on the down side that, can cause a bit of a shake every now and then. I've got friends who changed from Dexron to Transynd and said the shifting is seriously smoother.
Well, I did the "$250.00" change over to Transynd and, it shifts exactly like it did before. So, again, maybe a call to whatever service center or, Allison might be warranted.
Scott
Scott
