judylaverty's avatar
judylaverty
78 Blue Bird Breaker Box
Hi: We're new to the forum and happy to be here. We picked up our "new"
78 Blue Bird Wanderlodge and drove it home from Lovelock, NV to Truckee, CA. When we picked up the coach everything worked. After parking it at home, we can't get the generater started, none of the lights including the interior, turn signal, flasher, etc., dont work. All batteries are charged and the genny tank is full. We have searched to no avail to find the 12 volt breaker box or been able to figure out what is wrong. We did find a wire dangling down under the bus and it may be a ground wire. The owners manuals are useless as they refer to the breaker box but don't say where it's located. Also, the air step doesn't work either. We are beyond frustrated and completely puzzled. The coach starts up immediately, and the only thing that works is the sound system and the headlights. Can anyone out there give us some ideas as to where to start. Thanks, Bill and Judy
  • Thank you, everyone for your help. We will take your advice and search everywhere you suggested. Yes, we're on the Blue Bird forum also. I just know the fix is something simple that we are overlooking. We will keep you posted. Thanks again
  • look in the compartment under the booth by the door. there is a large transfer switch there. breaker box should be in a rear closet
  • sounds like you turned On a battery disconnecct switch someplace
    not an uncommon thing
    playing with switches, wondering what does it turn on or off
    battery disconnect ON..means NO power in coach
    you want battery disconnect OFF
    it could be a rocker switch, it could be a Heavy knob type switch, old fashion looking
    its common on the seller "walk thru" for the buyer to be so excited, he doesn't remember what the seller was pointing out
    wander lodge was always top of the line
    you got enough switches and gauges to rival a 747
  • Welcome to the forum
    I'm not familiar with your rig. On our 96 Southwind the breakers are located under the refrigerator.
    Start looking and following wires.
    Hopefully someone will post with the location.
    Did you reattach the ground wire?
    Also, did you search the web for a Blue Bird Owners forum?
    Enjoy your travels.
