centerline
Jan 15, 2018Explorer
a radiator pressure tester would tell you quickly if you have a leak, and if its internal or external... after 5-10 minutes, with an external leak you will see water leaking on the ground, and if there is an internal, you will see the pressure in the radiator dropping but no drips on the ground..
this doesnt answer your power loss issue, but its part of the troubleshooting process to find out what and why..
38,782 PostsLatest Activity: Sep 10, 2026
