Duramonster
Dec 03, 2015Explorer
Tom/Barb wrote:yeah ,mine does that also. As soon as you raise the idle the slightest, the pressure goes way upDuramonster wrote:
My 8.3 Cummins has low oil pressure at hot idle . I installed a mechanical gauge on the engine to make sure that it wasn't the dash gauge. It idles at around 8 to 10 Lbs. when hot . As soon as you bring up the idle to around 900 RPM ,it goes up to around 20 Lbs. and increases with RPM. At cold start , the pressure is right up where it should , but as the temp goes up, the pressure goes down. Engine sounds good and has been like that since I purchased it.
Google search "Cummins 8.3 oil pressure problems" tons of hits, of those who worry about the same thing
there maybe a oil pressure regulator problem. A slide kit may improve the problem. We will put one in our 8.3 next month for the same problem. ours on a cold start will peg the gauge. then when hot at idle shows 20. when at 60mph at 2000 RPM shows 60.
38,782 PostsLatest Activity: Sep 10, 2026
