DSDP_Don
Aug 08, 2016Explorer
"Tinstar"....take the measurement again, but use another ground like the frame near the lights or add a long wire to your meter and pick up a nearby ground. Just don't use the one in the light fixture. Monaco had issues with losing grounds and running undersized wiring. I had a couple of lights in my Diplomat where I had to run new grounds.
Once you resolve the power issue, you'll probably be happier with an LED replacement. You want LED's in the 3400 warmth range to give you equivalent colored lighting to your fluorescents.
