MattGinOK's avatar
MattGinOK
86 Dodge Falcon 190: Hot water tank valve and Front Springs
Hi yall!
Besides looking for manuals for my 1986 Dodge Falcon 190, I'm also looking for the drain valve for the hot water tank. I see what I think is the tube, but where do u drain it?
Also looking to replace the front springs as The drivers side leans about .5-1". Moog-7226S is as close as I can come. Problem is I can't tell what the ends are like. The dude at Moog said the bottom of the 7226s springs was 'tangential'. See link
Moog ad and end types
I've posted here some weight and other info. All I have. The pics of springs are not true pics of the spring being sold. It almost looks like a 'pull it out and look' kind of situation. The dodge 1986 lists the part number as 4116990 1825/2000#. Just throwing this out as someone may have removed one and remembers what's needed.
Some not very helpful pics
  • Well, I am a dummy. Thanks for your post, made me look a bit further. The drain was at the bottom of the heater compartment. I opened that and the filler at the top and it drained just fine. Man, I really feel as if my retirement has retired my brain sometimes.
    See Hot Water tank
  • IF that 'hot water tank' is a conventional rv water heater (suburban/atwood) then you drain it by removing drain plug and open a faucet hotside to allow air in
    Drain plug is in outside compartment under burner tube.
    Suburban drain plug will also be an anode rod so you unscrew it and remove the whole assembly
    Atwood would have a Nylon drain plug only
    Course who knows what previous owners have done ....modifications made???
    Can't help on front springs
