kwilkins's avatar
kwilkins
86 outside - 82 inside - AC running all day?
2017 Winnebago Sunova 36z with 2 heat pumps. This morning the AC's (both set at 70) started running non stop when it was 77 degrees outside. The temperature in the RV keep rising throughout the day; with both units continually running. The high today was 86 (Cape Hatteras, NC) and inside the RV it is still 82 degrees.
There is "coldish" air blowing through all the roof vents. I don't know if it is not as cold as it should be. We traded in a 2010 Sunstar that also had 2 heat pumps that kept the RV cool in weather like this, and even hotter. The Sonova is 4 feet longer and much bigger inside with 3 slides.
Does this sound normal to you, or do you think we have a problem?
Thanks for any advice on this.
Ken
  • Not normal. Is the humidity high outside?? Maybe the condensers have frozen up.
