carringb
Aug 19, 2020Explorer
Its the fuel pump. BTDT.
That generation Ford had pump impellers that swell with age when using E10 gas. That makes it run hot which causes vapor lock inside the pump. This is why cool weather or topping off with cold gas fixes it.
The newer Ford pumps will fit, and either Ford or the parts counter should include a wiring adapter to use the new pump.
