Can't find the convertor book says under clothes closet but not there . switch to 110 outside sorce thumps but batteries are dead and they are new, any help Thanks Jimmy
If your dc fuse panel is any where below waist height You will find the converter section is behind the fuses Unplug shore power, disconnect batteries Remove fuse panel to access converter Unless you have a blown main charge/battery fuse the converter charge section No battery power sounds like the main battery charge fuse is bad
Are batteries charged or dead Did you have power lights that slowly went dead? If so fuses are good , converter is bad
