psalm10720's avatar
psalm10720
94 Brave LP Tank Shocker!!!
I bought a used 1994 Winnebago Brave 27RC this past May and paid retail from a dealer. I opened the LP tank valve to start the flow of LP gas this past week and a leak developed around the valve. I was told the tank could not be repaired and would need to be replaced.
1st Shocker!! Just the tank was told to me to be around $600.00 and three hours of labor to install..
2nd Shocker… Camping world was told by Winnebago that they don’t manufacture the tanks anymore and the new design costs $1,100.00 for just the part and there needs to be adaptation changes to the coach to the tune of $750.00 for installation.
Has anyone found any other solutions for this type of project or some grounds to approach Winnebago on because of their design changes??
  • I had a valve leaking, shop emptied tank, took apart valve repaired cost $125. you need a propane shop not CW.
  • Are you saying there are generic tanks that can be mounted where the one now sits???
  • I am a long-distance truck driver. I was out on the road for weeks. The valve was opened after sitting for weeks and the leak simply occurred. It didn't have anything to do with it being filled...
  • did you take it to a real propane business. One that installs tanks at home type. If not check with them. This should have caught when propane was filled. A good company would not have fill it.
    A new frame mount only list $458 here local.
    guy call me back that price is for a 40 gal. A lot bigger than you probable could fit in the hole.
    yes they make tanks for frame mount in all sizes.
    Again check with your propane dealer first.
    You could go all electric.
