Golden_HVAC
May 02, 2013Explorer
You have Power Gear Bigfoot jacks, same system as I have. The red light is the "Jacks down warning indicator" that will only flash if the fluid level is low in the resivoir and you put the RV in gear, or release the parking brake.
You might have either 3 or 4 jacks. Yours is a newer system than I have, I do not have separate lights for the Netural sensor, or parking brake. I also do not have a "Extend and retract button" however I have a "All" button that retracts all the jacks. Mine is a 97 RV built in November 96.
The warning on the bottom, that says do not use to jack up to remove a tire is astern one, and justified, the jacks can retract without notice. When I changed my tire on the side of the freeway, I only put down the jack to level the RV, then used a 4 ton jack to lift the axle, and remove the tire.
Fred.
Fred.
38,769 PostsLatest Activity: Apr 03, 2026
