DFWRusty
May 02, 2013Explorer
Thanks for the info. I'm not sure if I have bigfoot jacks or not, I do know that the base is about 12" dia. and the shaft is about 2" dia. I have 3 jacks, 2 on the rear and one in the center on the front.
So far I have collected from y'all, that I probably need to check my fluid before I try using the system, correct? Once I varify that the system is full of fluid I set the parking brake, push the on/off button (do I hold it for a certain amount of time or do I just push it?), then push extend (all), then use the 4 adjusting buttons to level the rv? Then repeat process in reverse to rais the jacks?
One more question, does anyone know where abouts to looks for the hydraulic resevoir? I've never looked for it on my unit. Also, one of y'all said to locate the fuse, where would that typically be located? In the fuse pannel behind the dash possibly or is it going to be an inline fuse of some sort?
Thanks for the help guys!
38,769 PostsLatest Activity: Apr 03, 2026
