OnaQuest
May 02, 2013Explorer
DFWRusty wrote:
Thanks so much guys for all of the information! I have a lot of reading to do... lol... Looks like the cut the wire for the float switch.... hmmm..... doesn't quite fit the description they gave on the receipt about a level indicator, unless it's the same thing and the just used a lesser term. Either way, I'm going to try and learn as much as I can on this today and try and mess with this thing this evening.
The float switch and level sensor are the same thing.
Use the information in the manual that I linked you to. It's more likely to be accurate for your vintage levelers. It's likely that the switch is maladjusted. You'll see by the book that it needs to be oriented in a vertical plane.
38,769 PostsLatest Activity: Apr 03, 2026
