Gjac
May 03, 2013Explorer III
You have received good advice from Doug and others already. As a simple check if you don't have power(no lights)on your control panel, check for a blown fuse I found mine under a fuse marked ACC. It was caused by the 12 v wire that feeds the control panel being grounded. It got caught in the emergency brake mechanism.
38,769 PostsLatest Activity: Apr 04, 2026
